Can i use IRC 2880 toner on Advance C5035 machine
  • aungmoe
    • Apr 2016
    • 3
    Can i use IRC 2880 toner on Advance C5035 machine?
  • 20 year tech
    • May 2014
    • 577
    Re: Can i use IRC 2880 toner on Advance C5035 machine
    no
    • kuby
      • Oct 2007
      • 1386
      And NO !
        and one more NO
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Originally posted by aungmoe
          can i use irc 2880 toner on advance c5035 machine?
          and no no why would you even try
          Regards Mark
          • tech28
            • Jun 2013
            • 434
            Aside from them being totally different cartridges, you would need to empty the toner out of one to pour into the other one, and being if you are that cost conscious, get a compatible toner for 20 bucks off e-bay. But, let me add another NO!
            • copier tech
              • 8107
              Konica Minolta is the same toner from the C452 up to the 8 series.
              I have never tried on a Canon.
              I'm guessing you have a load of IRC 2880 toner but no longer have the machine?
              If you really want to try it you can empty the 2880 toners quite easily by popping open the cap pour out onto a piece of paper etc.
              Now you need to find a a way to 'top up' your 50xx bottles.
              Again if you really do want to try this only do a little at first then check the print quality. I would start with the yellow.
              Also if these are genuine Canon toner you could list them on ebay they still have a small value.
              • aungmoe
                • Apr 2016
                • 3
                thanks, my old irc2880 machine is no work already, and i have left those toner refill then i put on my new advance c5035 machine. what happen later i don't know?
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Wow iam surprised hopefully it's the same mixture and type of toner something I would never do keep a eye on your copy quality good luck
                  Regards Mark
                  • copier tech
                    • 8107
                    It is a bit of a gamble thats why I said try only a half cupful etc & check the quality before you add more.
