IPR C800 cyan light lines
  • pnai
    • Jan 2020
    • 23
    Dear,
    I'm have a problem with the imagepress c800 cyan color, if I make one copy the image is perfect but if I make multiple copies light vertical lines appear on the image, the Drum and developer unit are new, any suggestions .
    Note: where can I download the service manual for IPR c800.
    Many thanks and stay safe
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: IPR C800 cyan light lines
    Originally posted by pnai
    Dear,
    This is a production machine best to only work on them if you are trained. Good to see a sample also what's the pm life's
    Regards Mark
    • pnai
      • Jan 2020
      • 23
      Thank you mga for your reply,
      attached a sample for the test print , I changed the drum blade but still the same problem.
      many thanks
      • GIUBOSS
        • 1406
        many thanks
        Developer cyan is probably corrupt , lumps of toner or fluff inside, try filtering it through a sieve, try not to disperse it otherwise I will regret it
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          +1 Develop assy / dirty laser
          Regards Mark
