Canon IPF750 - head replaced, head cleaning gives 03800500-2F42
  • justroll
    • May 2020
    • 2
    Hi i got a beauty
    I took it over from a friend in order to repair it in full, bought a new head, replaced it, did a nozzle check and it gives me this
    2 boxes are gone
    when performing a head cleaing i get 03800500-2F42. I'm aware that he has pushed the previous head over the top, +2800 days, could this have damaged the main board ? I still see prices for main boards at being way to expensive for this repair> $650
    prints are still ok ; what to do ?
  • charm5496
    • 2387
    Re: Canon IPF750 - head replaced, head cleaning gives 03800500-2F42
    I would look at the purge unit and/or the carriage unit. Looks like you have a lack of air suction. Check your tubes for air pockets in them
    • copier tech
      • 8192
      Originally posted by justroll
      Hi i got a beauty
      [ATTACH=CONFIG]45745[/ATTACH]
      2 boxes are gone
      If the prints are Ok I wouldn't worry too much however, what ink is in the machine, genuine or 'refilled?'
      • justroll
        • May 2020
        • 2
        its original intkt, prints are great, just nozzle check gives those two down .. it makes me crazy to know why it's not working, the previous head had the same problem
          have you checked the head cable/connections?
          what units are you trained on?
          do you have a manual? ( a MUST on these )
          • Canuck
            Tech Specialist
            • 1713
            Cap absorbers ever been replaced? If mixed colors on nozzle check, a lot of the time it's plugged cap absorbers. And overdue printheads will short and fry main controller
            • niyaskarimba
              • Sep 2014
              • 110
              Kindly check & clean the Cap aborser on the purge unit.If it is damaged,kindly replace.
              • shazza
                • Nov 2009
                • 96
                Cannon IPF 770
                Anyone got Part Numbers for Absorber Pads X 2?
                Only Purge Unit listed in Manual
                Shazza
