Latest L Printer Service Tool
  • davidvidgen
    • May 2020
    • 3
    • 2621
    Re: Latest L Printer Service Tool
    Found this, not all Canon firmware is restricted to techs.
    imagePROGRAF iPF6100 - Support - Download drivers, software and manuals - Canon UK
    Copytechnet search tool v0.8 Final
    • davidvidgen
      • May 2020
      • 3
        • 22808
        then logic would tell me to address the cover open problem.. is it getting power? does the switch test good?
        so many questions so little information given
        • davidvidgen
          • May 2020
          • 3
          Yes switch is good and power is present.
          When I first powered up the printer it performed routine cleaning, but it attempted the cleaning process around 3 times. This was unsurprising given it had not been used. During this operation the call service message appeared. I powered it down, left it 2 hours and then powered up again. This is when the close top cover message began to show. Printer will not go into service mode.
            • 2621
            Its a problem with the top cover sensor what happens if you cheat it ?
              • 22808
              Beat me to it brother.. been in the yard literally just about all day!
              • charm5496
                • 2387
                Doesn't the top cover have a switch and sensor system to manage its open/close status on this model?
                If so, you might be missing part of the system.
                • charm5496
                  • 2387
                  Did a quick search and this issue has several hits on the tech support site. Issues with the ribbon cable, power supply, main controller, carriage units and print heads. Happy troubleshooting
                  • copier tech
                    • 7931
                    Originally posted by davidvidgen
                    Thanks skynet.
                    Yes, I have the firmware update tool. The issue I have is because the printer consistently states the top cover is open, and therefore offline it will not update the firmware. The same applies when I put it in firmware download mode, because the printer is offline it won’t perform the update. My understanding is the L printer service tool will allow me to bypass the error message.
                    Whilst the printer itself is 12 years old, it has only been used for about 6 months and then in storage. No issue with sensor etc, so it maybe a case that the eeprom memory may have become corrupt. Nearest canon printer repair is over 100 miles away.
                    If this printer has only been used for 6 months then in storage I imagine even if you do sort the cover open issue that will only be the start of the problems you're likely to have with it, most likely the printhead will need replacing & these are very expensive.
