IR 2270 Printing error
  • thish.csoffice
    • Jun 2020
    • 9
    Hello guys this is my first post to the community.
    I am having a problem with ir2270 printing. I have checked version of the machine and it says " bootrom C". And no any pcl or ufr added in device configuration list. So the question is there a way to able to print documents with this printer without making any hardware changes or what should i do to solve printing issue?
    Network port is not working at all but usb printer interface.
    I have attached some photos of s.mode. please help me to solve this
    Sent from my STK-L22 using Tapatalk
  • aco.bk
    • Sep 2012
    • 130
    Re: IR 2270 Printing error
    There is no way to print with C bootrom on this model....
    Poslato sa MRD-LX1 pomoću Tapatoka
    • thish.csoffice
      • Jun 2020
      • 9
      That means i have to swap bootrom c with bootrom n?
      • aco.bk
        • Sep 2012
        • 130
        Replace bootrom and try UFRII print driver.
        • thish.csoffice
          • Jun 2020
          • 9
          Do you know how to purchase a bootrom ? Because of i imported this machines from france and no support center in local
          • copier tech
            • 8133
            Back when this model was released Canon sold printing as an OPTION!
            The LAN port will still work, so you can network the machine but all you can do is open the RUI (machine web page) you can't print or scan.
            You will need to get an N boot ROM & RAM then update the system software.
            Or if you can purchase the printer kit (see attached) but obviously this has long since been discontinued, however have a search on eBay you might be lucky.
            Canon iR2270-2870 Specification.pdf
            • thish.csoffice
              • Jun 2020
              • 9
              [ATTACH]45963[/ATTACH]
              Image is not visible. Can you quote again plz
              • copier tech
                • 8133
                It's not an image it is a PDF document showing what print kit you need.
                  Those print kits are as rare as rocking horse shit but there's one here
                  Canon Multi-PDL Printer Kit-E1
                  Is it worth it?
                  can you print via usb as it is ?
                    opened fine for me.. it's in PDF format
                    • copier tech
                      • 8133
                      Is it worth it?
                      No not worth it on this old model however if he can pick up a used rom kit cheap then maybe.
                      No can not print via USB without the kit.
                      • thish.csoffice
                        • Jun 2020
                        • 9
                        That's true it is not that worth to purchase for such an old model. Thanx all for helping me out. I will check out for used kits as u mentioned.
