Jam on adf
  • Reeves
    • Apr 2012
    • 296
    [Jamming] Jam on adf
    I am working on the can ir5065 copier when I use the platen glass machine is working okey but when I use adf as soon as I put a sheet of paper to ADF and hit start, copier shows paper jam the massage won't clear turn off and on jam is gone.
    I clean all sensors and reflective pads.
    Please help.
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Jam on adf
    What jam code do you get?
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • Reeves
      • Apr 2012
      • 296
      Re: Jam on adf
      094
      • Reeves
        • Apr 2012
        • 296
        Re: Jam on adf
        Please help.
        When I go into service mode FEEDER when I go to FEED-ON press okey it's not feeding the paper the green light on adf will jst start bringing continuesly
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          Re: Jam on adf
          Title : 0094 Jam Code
          Problem :
          The document feeder is generating a 0094 jam code that will not clear until the machine is power cycled.
          A 0094 jam code can be generated by any paper path sensor in the document feeder. PI1, PI11, PI12, PCB2, PCB3 and PCB4 can cause this type of jam.
          Solution :
          In this instance, a foreign object was found interfering with the flag actuator operation of PI11.
          Title : Jam Code 0094
          Error :
          The DADF-S1 indicates a jam as soon as you try to use the document feeder.
          Jam code 0094 shows up in the Jam history in service mode.
          In service mode level 1 > Feeder > Function, SENS INIT was performed and the result was OK.
          Workaround :
          In this case, it was found checking the state of the DADF-S1 optical sensors (PCB 2 - Post Separation, PCB 3 - Read and PCB 4 - Delivery/Reversal) in service mode level 1 > Copier > I/O > Feeder, that the state of PCB 4 indicated that paper was present (address P006 - bit 1 indicated a 1).
          Replacing PCB 4 resolved the Document Feeder jamming issue. Part number for PCB 2 / PCB 3 / PCB 4 is FM2-1022-000.
          I/O address for PCB 2 is P004 - bit 4; a 1 indicates that paper is present.
          I/O address for PCB 3 is P006 - bit 4; a 1 indicates that paper is present.
          Title : 0094 jam code
          Error :
          The document feeder jams with any original that is attempted to be fed through it. The jam history displays a 0094 jam code.
          Workaround :
          When the machine jams in this manner and displays this jam code, check and set the following:
          Service Mode>Feeder>LA SPEED and Service Mode>Feeder>DOCST with the door label.
          Also run Service Mode>Feeder>Function>Sensor INT, for sensor initialization.
          After doing so, power cycle the machine to make sure the settings are retained in Service Mode.
          Title : The DADF S1 does not feed paper and displays a 0094 jam code.
          Problem :
          When the originals are placed in the DADF-S1 document tray and the start button is pressed the originals are not fed and the machine displays a 0094 jam code.
          Solution :
          In this case, the cause was the registration sensor PI 1 not being supplied the proper voltage. The 5 VDC supply on connector J411 pin 2 on the feeder controller measured less than five volts. Removing the tie wraps from the wire harness J411 corrected the jam problem.
