iRA 6055
  • Gab
    • Aug 2015
    • 671
    #16
    Re: iRA 6055
    Also machine rotates toner bottle.
    The part that has the crack is Stopper, bottle link inner door (FCB-4692-000). cAN IT CAUSE THE PROBLEM?
    • Drivee
      • Nov 2020
      • 322
      #17
      Re: iRA 6055
      If issue is ghost araund letter, it can be bad toner... clean dev units, use OEM toner and see difference.
      • Andyboachie
        • 185
        #18
        Re: iRA 6055
        Originally posted by Apach
        Hello,Does anyone know what the problem is? I changed: Drum cleaning blade, pre and primary corona and developing assembly, but problem is not solved. Maybe some parts is not working properly?[ATTACH=CONFIG]46164[/ATTACH] First page is every time is OK but next pages not.[ATTACH]46164[/ATTACH]Thanks on advice.
        What is the situation of the cleaning web and the upper fixing roller? Expect this output if the web is dirty or not cleaning. The fact that the problem occurs at the trailing part of the copy seems to imply a particular area of the drum can cause this too. So my suspicions are the drum and the fixing roller.
        • Canuck
          Tech Specialist
          • 1713
          #19
          Re: iRA 6055
          Check if your pre-exposure LED is coming on. It's mounted in the cleaner blade assembly. It's connector is the one that you disconnect to remove the cleaner blade assembly. Probably forgot to plug it back in.
          • Brian8506
            • 1664
            #20
            Re: iRA 6055
            Good point. Been there.
            • Gab
              • Aug 2015
              • 671
              #21
              Re: iRA 6055
              Is dev roller surface ok . Clean it.
              I bet on charge
              • WLIT
                • Jan 2020
                • 40
                #22
                Re: iRA 6055
                As someone said before pull the process unit again and check for a good connection at the blanking lamps. Not much wire there and it's easy to disconnect by accident.
                • Brian8506
                  • 1664
                  #23
