iRA 6055
  • Apach
    • 157
    iRA 6055
    Hello,
    Does anyone know what the problem is? I changed: Drum cleaning blade, pre and primary corona and developing assembly, but problem is not solved. Maybe some parts is not working properly?Problem.pdf First page is every time is OK but next pages not.Problem.pdf
    Thanks on advice.
    There is no stupid question, just stupid answer
  • giogi
    Engineer senior
    • Jan 2016
    • 180
    Re: iRA 6055
    I suggest you polish the surface of the drum and clean inside the laser group.
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • copier tech
      • 7931
      Re: iRA 6055
      Originally posted by Apach
      Hello,
      Does anyone know what the problem is? I changed: Drum cleaning blade, pre and primary corona and developing assembly, but problem is not solved. Maybe some parts is not working properly?[ATTACH=CONFIG]46164[/ATTACH] First page is every time is OK but next pages not.[ATTACH]46164[/ATTACH]
      Thanks on advice.
      What is the life of the drum? if it is over 1 million you can polish it with Brasso & cotton wool.
      • Apach
        • 157
        Re: iRA 6055
        Drum have a 1.4M copies. I try to polish. Tnx for advice
        • Brian8506
          • 1623
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Re: iRA 6055
            Replace the complete main charge assembly, run 200 prints and charge issue should resolve itself.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • copier tech
              • 7931
              Re: iRA 6055
              Read what the posted said he had replaced the primary & pre charge units.
              • Venom
                • Nov 2009
                • 765
                Re: iRA 6055
                Guess it depends how it is read, could be rewired main and pre transfer plus dev unit. Could be used units installed.
                • copier tech
                  • 7931
                  Re: iRA 6055
                  "Replace the complete main charge assembly"
                  I don't think that could be any clearer.
                  • Ingranaggio_rotto
                    • Oct 2010
                    • 274
                    Re: iRA 6055
                    Hello,
                    Thanks on advice.
                    Have you tried disabling the potential control ?
                    Have you checked the electrical drum mass?
                    • nicknt82
                      • Nov 2011
                      • 116
                      Re: iRA 6055
                      Hello,
                      Thanks on advice.
                      Check or Fixing Upper Roller, It catch toner and preprint on image
                      • COPIERTEC ASSOCIATES
                        • Aug 2011
                        • 276
                        Re: iRA 6055
                        Hello,
                        Thanks on advice.
                        From the look at your copies,there is no constant flow of current from the HVT board(pcb).
                        I would suggest you look at the HVT board for possible dry contacts basing on the number of
                        copies your machine has made.
                        Secondly the connector of the blank lamps.
                        When you perform a test print from the copier does the copy still give varriations in print?
                        If so look at the factors above
                        • Apach
                          • 157
                          Re: iRA 6055
                          At the moment I have a lot of jobs and don't have time for repair. I ordered all new parts again because I have 4 same machine(parts is always needed ) and next week I try to change parts by parts and again check PCB. I post results here when I finish. Again, thanks for your advice guys.
                          • Hishamawada
                            • 174
                            Re: iRA 6055
                            Hello,
                            I dont know if you fixed the problem or still.
                            The issue seems from the Etb assembly ( the text is being reprinted ), better change brush and the blade first with cleaning the etb assembly rollers , if not solved you can try the belt also.
                            For the top issue if its not solved along with the above parts , it could be related to the drum since it looks like the drum surface.
                            • Gab
                              • Aug 2015
                              • 633
                              Re: iRA 6055
                              It looks like charge to me
