"The feeder needs to be checked"
  • Toner Monkey
    • Jul 2020
    • 1
    [Misc] "The feeder needs to be checked"
    Hi all,
    I have a Canon IR C5535i that had a faulty DF Driver PCB. After replacement the machine says " The feeder needs to be checked, contact your service rep." and locks down the ADF. Looked at all the error clears in FUNCTION-MODE but nothing related to the ADF.
    Any ideas appreciated.
  • 20 year tech
    • May 2014
    • 580
    Re: "The feeder needs to be checked"
    update your firmware
    • giogi
      Engineer senior
      • Jan 2016
      • 180
      please check: Management settings > device management > limited functions mode
      other check: SORTER>OPTION>MD-SPRTN > 0
      easy
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • MunsterTech
        • Sep 2014
        • 376
        easy
        he says Feeder needs to be checked, not the finisher? I saw this once, when i was cleaning the duplex scan glass, which is under the pull down platten glass cover, i was cleaning the glass and it moves back and forth, i still to this day dont know what exactly i did but that message came up after i finished cleaning. I fiddled around with the glass again and rebooted the machine and the message went away. I know one tech who had this and to this day could never get it sorted. Canon didnt know of it either! Sorry best i can help you with
        • zuckryyu
          • Jul 2019
          • 31
          easy
          I have a problem with my adf....it does detect paper..but the roller at the top does not come down to pull the paper...(it does come down,but after i put paper, immediately the roller going up)
          Things i already do
          - change adf clutch
          -change feed roller
          Any advice from professional?
          Canon ir adv c5035i
          Sent from my TA-1021 using Tapatalk
          • Blizzoo
            • Aug 2013
            • 588
            Things i already do
            - change adf clutch
            -change feed roller
            Canon ir adv c5035i
            Start your own thread Mister!
            • rspicer
              • Oct 2015
              • 97
              I just had this happen to a 5540 (gen II) yesterday. It also had an error in the history that referred to the DADF scanner not able to set the white level. Because it was in a very dirty environment, I pulled the scanner from the DADF and cleaned it really well, but it still didn't clear the message. I even tried to set the white level, but it immediately failed without even trying to feed the test page into the doc feed.
              I looked at the firmware, and it was a few levels behind, so I upgraded it to see what would happen. After the firmware upgrade, it came to ready with the doc feed fully functional, and it let me do the full white level adjustment. If you ever see this message, definitely try the firmware first.
