E553-8001-2 / Staple Finisher-Y1
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    [Error Code] E553-8001-2 / Staple Finisher-Y1
    Collected this finisher from the customer on Friday and brought it back to the workshop.
    Of course I have what is says below as a starting point.
    Just thought I would ask for any additional pointers before I roll up my sleeves and get medieval on it.
    E553-8001-02: Error in the Escape Delivery Shift Motor (Finisher-Y1)
    Detection Description
    The lower escape delivery roller does not come off the Escape Delivery Roller HP Sensor when the Escape Delivery Shift Motor has been driven for 1 second.
    Remedy
    STAPLE FIN-Y1/BOOKLET FIN-Y1
    [Related parts]
    - Harnesses from the Escape Delivery Roller HP Sensor (PS112) to the Finisher Controller PCB
    - Harnesses from the Escape Delivery Shift Motor (M106) to the Finisher Controller PCB
    - Escape Delivery Roller HP Sensor (PS112)
    - Escape Delivery Shift Motor (M106)
    - Finisher Controller PCB (PCB101)
    [Points to note at work] When the Swing Guide Safety Switch (SW102) turns on at the detection timing of this error, this error code may be displayed. Accordingly, perform the following work before checking the related parts.
    1. Check whether there is not the malfunction in the swing guide unit.
    2. Check whether there is not the malfunction in the Swing Guide Safety Switch (SW102).
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] When replacing the Finisher Controller PCB, refer to "Adjustment> When Replacing the Parts" in the Service Manual.
  • 20 year tech
    • May 2014
    • 577
    Re: E553-8001-2 / Staple Finisher-Y1
    clean these bushings
    • Cipher
      • May 2006
      • 1309
      Looks promising, I'll let you know.
