Does anyone have these out there that after the initial skew adjustment is set(or not set), that the image moves around on its own?
by moving around I mean EITHER of the following: shift to lead edge, shift to trail edge, rotate clockwise, rotate counterclockwise...
It will stay true for a few days and... i get call again...
is there a tried and true skew adj procedure?
The Pink calibration sheet was said not to work per N78-002, but I havent seen any of the newer black border sheet yet..
*skew issue*
*skew issue*
