IR-ADV 65XX Admin password forgot
  • techsup
    • Oct 2019
    • 6
    [Error Code] IR-ADV 65XX Admin password forgot
    Dear Team,
    Kindly help me to overcome from this issue your immediate support would be much appreciated
    Scenario :
    Customer X IT person messed up this device security settings and now they have realized the machine has issue
    1. Changed Administrator password
    2. Enabled Restrict Service Representative Access - ON
    3. Enabled Prohibit Initialization of Administrator Password - ON
    Actions taken so far :
    1. PWD-CLR executed
    2. MMI Cleared
    3. PLPW-CLR DONE
    4. MN-CONT EXECUTED
    5. Unable to update the firmware because machine is in "Restrict special Mode Operations " mode
    6. Unable to format the HDD( With Service mode & SST ) because machine is in "Restrict special Mode Operations " mode
    Kindly advise the way forward
    Tech
  • 20 year tech
    • May 2014
    • 577
    Re: IR-ADV 65XX Admin password forgot
    Start the Machine in 2-8 mode and initialize the HDD
    • techsup
      • Oct 2019
      • 6
      Dear ,
      Thanks for your reply . I have tried 2+8 bootup but the machine initialized with download mode and stating that " download mode cannot be used " because the machine in in restriction mode
      expecting your possible support
      Regards
      Tech
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        Have you to try to get into the RUISettings/Registration : Management Settings : Device Management > Access limit settings responsible for assistance
        and change the setting?
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • 20 year tech
          • May 2014
          • 577
          Forgot this is done with a license now. If your not a canon dealer you will need to contact one. Licensing can now be done online (In the states anyway) now that Canon finally got most of Esupport back online today.
          Product : imageRUNNER ADVANCE 4500 / 5500 / 6500 / 8500 Series
          Title : Administrator password clear workflow.
