faded paper at the top canon ir 2520
  • zefa
    • 11
    i bought the machine 2 month ago then the toner cartridge was empty and it says at the bottom prepare the toner then paper started to be faded after i replaced the toner cartridge, it still the same faded paper at the top
    any solution ??
  • copier tech
    • 8144
    Re: faded paper at the top canon ir 2520
    any solution ??
    [ATTACH=CONFIG]46505[/ATTACH]
    Looks like the dev unit is depleted of toner.
    Take out the developer unit & check the coating of the roller on the front/rear.
      Is it a genuine toner?
      If you are a tech you can go into service mode and try toner install.
      • zefa
        • 11
        how can i clean it correctly
        • zefa
          • 11
          yes its C-EVX33 and i did toner installlation all the paper is good except the top part as the pic explain.
            You don't need to clean it, is there a nice even coating of toner all along the magnetic roller?
            Is the laser glass clean?
            • livancicm
              • Sep 2008
              • 96
              clean the poligon mirror
              • zefa
                • 11
                iam goin tomorrow to the work and will see that , its faded in printing also not scaning so is poligon mirror the cause ?
                  Depending on how old the machine is and how many copies it has done that is a possibility.
                  • zefa
                    • 11
                    its new i bought it about 2 month ago and made like 20k copies
                    • copier tech
                      • 8144
                      Is the machine level?
                      • zefa
                        • 11
                        if you mean its new yes its new.
                        • copier tech
                          • 8144
                          (google this word) the toner can move to the back or front.
                          • tsbservice
                            Field tech
                            • 8016
                            Looks like either mag roller is poor covered in that area for some reason(leveling in example) or dusty poly mirror.
                            • doktor
                              • 214
                              Remove and clean laser.
