Canon D1320 light along one edge
  • partly retired
    • Oct 2019
    • 31
    Using OEM toner. Very light image along entire edge whether thru DF, glass or print job. Side closest to operator when placed on glass or on the right side of paper as it exits the copier. Can a PCR roller, which I cleaned, be bad in one section of roller? Stopped image while making copy (yes image light on drum) to rule out fuser. No slit glass between laser and toner cart to get dirty. Suggestions? Thanks
    Re: Canon D1320 light along one edge
    I HAVE NEVER SEEN A LASER UNIT WITHOUT PROTECTIVE GLASS.... DOUBLE CHECK.
    it this the first time it has been serviced?
    what are the page counts on drum/service parts?
    what does the dev unit look like? it the less of a brush on the roller in the spot of defect?
    what about transfer roller? is it out of place?
    upload examples in PDF format
    Phil B. ' The Dentist '
    • tonerhead
      • Sep 2009
      • 582
      Not really an expert on this model, I will say drum is rated 24k and images probably will get lighter as drum ages. Have worked on similar canons. When charge roller gets dirty, image gets lighter and full of streaks. It is opposite of what I thought it would do if dirty. I personally would flip in a new drum assy and I think that will fix it all. As brought up in another thread, copier is level, correct?
      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
      Especially when it comes to sex
