IR ADV 4525i scan issues
  • stevee104
    • Mar 2007
    • 214
    Trying to set up smb scanning to 2 computers that return a error of check server which they are not on
    a server. All fields are correct on copier and it will scan to my laptop connected to there network, also we have 2 kyocera's
    in the same office that scan smb also with no problems to both computers. Both computers and my laptop is running windows 10.
    My hair has turn gray on this one any thoughts.
    Thanks Steve
    Re: IR ADV 4525i scan issues
    Thanks Steve
    post your net config page in PDF format
    does the copiers have SMB v2 turned on?
    • copier tech
      • 8143
      Thanks Steve
      Canon use the term 'server' to mean PC/computer.
      Update your firmware and/or check SMB v2/3 is enabled.
      • stevee104
        • Mar 2007
        • 214
        Firmware is up to date and smb2/3 turn own, sorry
        for not mention it in earlier post.
          for being here since 2007 you have NO INFORMATION in your profile
          are you trained on ANY product?
          or are you an end user?
          • stevee104
            • Mar 2007
            • 214
            KYOCERA dealer, canon copier came with the business when it move here last week. They bought
            2 copiers from us and asked if we could set the canon up too and we told them we would
            give it shot and believe me i did a lot of searching before posting here.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Try creating a new user on the customer's PC, something simple like User: Scans and Password Scans. At the Canon: Setting/Registration> Set Destination> Register Destination> Register New Destination> File> Browse (This way you navigate to Network, Computer) Use the new credentials and then you will see Shared Folders available. Other thing to try, check DNS settings....maybe use IP address instead of Host name to verify. If all else fails....If you get it scanning on one PC, you can map that drive folder on the other PC's
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • stevee104
                • Mar 2007
                • 214
                Thanks will head back to customer office next week taking a long weekend,
                again thanks.
                • duxxa
                  • Sep 2020
                  • 5
                  Check to make sure no software firewall/antivirus is running on the machines. Norton and McAfee especially give me issues aswell as kaspersky.
                  • stevee104
                    • Mar 2007
                    • 214
                    Here are the Network config sheets , couldn't get them to upload as one attachment.
                    • Big Flo
                      • Jun 2018
                      • 15
                      Not Canon. But Microsoft.
                      " The Server Message Block (SMB) Protocol is a network file sharing protocol, and as implemented in Microsoft Windows is known as Microsoft SMB Protocol." -- docs.microsoft.com
                      • cyclone
                        • Apr 2019
                        • 4
                        I think NTLMv2 has to turned on to scan on Win10
                        • stevee104
                          • Mar 2007
                          • 214
                          Thanks I see it was turn off , will get it turn on and see what happens
                          got them scanning by email as of now.
                          Thanks Again
