Only LED green light on iRC ADVANCE 2020i
  • ernesto
    • Oct 2011
    • 430
    HI
    I have a machine irc ADVANCE 2020I only led green light is on in the panel control, panel is totally black you cannot see the bar, only you can listen any fan running all the rest of the machine does not move
    does anyone know the problem?
    it happens the same in a irc 3580 and it was the main controller finally
  • GIUBOSS
    • 1433
    Re: Only LED green light on iRC ADVANCE 2020i
    Try removing the memory and boot dimm reinsert it after cleaning the contacts, also interfaces and option cards. Also check the pcb fuses. Lastly, the controller board or power supply board is probably faulty.
    • ernesto
      • Oct 2011
      • 430
      I removed the memory an boot dimm and reinser it after cleaning the contacts but it does not work .....
      i am gonig to replaced the power supply first, if it doesn t work I ll replace the controller board but
      in this machine there is 2 controller board, the manin controller pcb1 and main controller pcb 2, which one should be replaced first ?
      i hope your answer
      All the best
      • GIUBOSS
        • 1433
        A tip, if you have to buy new boards it doesn't suit you, find a cheap used machine and replace the boards.
          i hope your answer
          All the best
          before replacing ANY board get out your manual and multimeter test the voltages coming in and out of the LVPS ... then test for continuity of the harnesses if the LVPS tests good.
          • ernesto
            • Oct 2011
            • 430
            I replaced the main controller pcb1 irc2020 (FM4-3139-000) and it is working again
            ALL the best
