5065 canon
  • kings5586
    • 23
    5065 canon
    Print jobs and test prints come out fine,but when copying or scanning copies come out washed out with random black grid lines.Replaced cable.reader controller,memory bd Cable.Thanks
  • SCREWTAPE
    • Aug 2025
    How do the mirror's look (optics), has the white plate been cleaned have thought about trying the xenon lamp, also you could try doing a CDD adjust. Since you have already replaced the reader controller check those two other componets; The CCD and lamp, Post back. Good luck!
    Screwtape.
    • kings5586
      • 23
      Thanks fo the info. i"ll check it out and get back with the fix
      • kings5586
        • 23
        Screwtape.
        CCD took care of the problem. Thanks
        • kings5586
          • 23
          • froozen
            I can CANON
            • Dec 2008
            • 20
            clean the optical parrts and clean mirror inside ADF
            Bundan ötesi ;
            Ya İSTİKLAL , Ya ÖLÜM!
            • froozen
              I can CANON
              • Dec 2008
              • 20
              then put 10 blank clean sheets on ADF then make ADF Celaning. (its in technician mode * )
              Bundan ötesi ;
              • SCREWTAPE
                • Aug 2025
                NICE! Thanks for posting back with the solution.
