design component motor drive canon ir 5000/6000/6020
  • margono
    • Aug 2017
    • 14
    [Electrical] design component motor drive canon ir 5000/6000/6020
    Are there any friends here who know the component paths on the motor drive canon ir 5000 ,, I need to check the damage path to the rigth deck motor
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: design component motor drive canon ir 5000/6000/6020
    What is actually happening? Is the deck not raising paper? If so check on the acuator switch on the assembly.
    2 Check on the pcb responsible for cassette drive if ok just change the motor assembly of the paper deck.
    • Brian8506
      • 1665
      I've also seen customers slam the deck drawer in and knock the tray recognition sensor assembly off the inside wall behind the deck.
