nethawk usb cable
  • cdvidaceiba
    • 80
    nethawk usb cable
    hi , where can i get one of this cables ???
    thanks in advance
  • Claudio
    • Feb 2007
    • 235
    Don't know what that is but Fry's Electronics seems to have all the computer goodies.
    • wingnut132
      • 65
      Canon is not making them anymore, and the people with them are not letting them go
      • cdvidaceiba
        • 80
        ok , you think that a paralled pc card can work ?? my laptop doesnt have a paralled port intergrated
        • copicatt
          • Nov 2008
          • 366
          For that very reason, I finally broke down and got an ibm t41 laptop last week on ebay. Parallel port is on it and gonna save me a lot of trouble, I hope.
          • SCREWTAPE
            • Aug 2025
            Keep in mind if you have i models such as iR3300i,3320i,5020i,6020i, those models can be upgraded thru fixed IP. Later models such as iR5000, iR5000s,iR5000d require that USB to Parallel Interface Cable (item # FY9-4154-000 to upgrade firmware. Not to sure about the card thing though? Also the nethawk driver is not compatible with Vista's OS. Good luck trying to find that cable.
            Screwtape.
            • cdvidaceiba
              • 80
              i get this from ebay it says that suport ECP mode , you think that can work??
              • SCREWTAPE
                • Aug 2025
                Looks legitable!
                I don't see why it would't work.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  The only stumbling block will be whether the Nethawk driver recognizes it and therefore whether or not SST will accept it.
                  • kuby
                    • Oct 2007
                    • 1409
                    Have you tired the one at Cables To Go. Do not know if it will work, I will have to get a laptop without a parallel port and try it.
                    Cables To Go - 6ft Port Authority USB IEEE-1284 Parallel Printer Adapter Cable
                    • cdvidaceiba
                      • 80
                      • Electrictoner
                        • 48
                        have you thought of a docking station too
                        I have had guys bring there docking station to flash machines with the para ell to centronics. Also the bigger hard drives WM2-3240-000 require later SST tool version 4.X I believe for the 2200 series.
                        let me know ET
                        • mrfixit51
                          Lead Service Technician
                          • Oct 2008
                          • 1975
                          Hi Oze,
                          The adapter shown in the previous post looks like it might be the ticket,
                          and if an IEEE1284 cable is used with that adapter, you will not have to
                          worry about any nethawk driver. It looks promising! Hope someone will
                          keep us posted.
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            Hi cdvidaceiba,
                            The reason you only have the centronics and ethernet options in SST,
                            is because you don't have the nethawk driver loaded. I assume that the
                            driver will not work properly with anything but the actual nethawk cable.
                            • cdvidaceiba
                              • 80
                              thanks i am waiting for the adapter to test it , i will let you know if this works
