IR7095 Network plug
  • seeriuss
    IR7095 Network plug
    Our company would like to print to our 7095s, but the network cable plug is nowhere to be found. Does anyone know where it is. Or does anyone know how to get a manual for it?
  • xcopytech
    • Aug 2006
    • 1794
    think you need network card if you want to print
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      That would explain the lack of RJ45 jack.
      Network kit?
      Upwards of $3000 for that particular model...IF you can find one.
      • SCREWTAPE
        • Sep 2025
        First, what version is the 7095? V1 or V2.. To make a connection, the Ethernet port is at the rear left you will also see the USB port as well. The multi PDL printer kit H1 or H2 is require for networking, the kit comes with the N. bootrom chip. Keep in mind, If the 7095 has been updated to V2 V50.xx or higher, then printer kit H2 is required, If V1, then H1 is required.
        Call a canon dealer for futher help.
        • seeriuss
          Thanks for the help!
          I finally found the network plug. It was tucked way up unde another connector. No wonder I couldn't find it! It helped to know where I was looking.
