Our company would like to print to our 7095s, but the network cable plug is nowhere to be found. Does anyone know where it is. Or does anyone know how to get a manual for it?
IR7095 Network plug
First, what version is the 7095? V1 or V2.. To make a connection, the Ethernet port is at the rear left you will also see the USB port as well. The multi PDL printer kit H1 or H2 is require for networking, the kit comes with the N. bootrom chip. Keep in mind, If the 7095 has been updated to V2 V50.xx or higher, then printer kit H2 is required, If V1, then H1 is required.
Call a canon dealer for futher help.Comment
seeriuss
Thanks for the help!
I finally found the network plug. It was tucked way up unde another connector. No wonder I couldn't find it! It helped to know where I was looking.Comment
