Image Tilts on Both Printed and Copied- IRAD5030
  • Andyboachie
    • 185
    Hello,
    I've been having a situation with an IRADV 5030 I'm working on. Copies tilts kind of diagonally. I earlier worked on cleaning the laser units. I felt I might have caused the error whilst assembling them. So I removed and fix them again. As I tried reading the service manual I have not been able to find any adjustment that deals with an error like that.
    Has anyone ever solved a kind of error like that?
    Kindly share your suggestions out of your experiences.
    I have attached copies of the output. The arrows show where the tilt occur. This appeared on copies made on landscape orientation. It is not so visible with portrait ones.
    Thanks in advance!
  • copier tech
    • 8236
    Re: Image Tilts on Both Printed and Copied- IRAD5030
    Originally posted by Andyboachie
    Hello,
    Thanks in advance!
    OK first, does this skew happen only when photocopying or also when printing?
      • 16560
      In the title is says both prints and copies.
        • 16560
        Assuming the image was aligned properly before you removed the laser unit, and that's all you did, I suppose you didn't reinstall the laser unit correctly. That would be my guess.
        • mojorolla
          The Wolf
          • 2639
          Run a copy and print in both orientations ( portrait, then landscape). Be sure to use different paper drawers as it could be as simple as worn rolls testing from the same drawer. If different orientations and paper sources show the same skew, the laser is not aligned properly.
          • Andyboachie
            • 185
            Initially, that is how I felt. But the laser unit has a definite way it fixes. There are raised areas at the base that fix into exact holes. Once I had all of them evenly fixed into the holes, I thought I fixed them right. I wish there is another culprit I'll need to attack on it.
            Thanks for the suggestion all the same.
            • tsbservice
              Field tech
              • 8080
              Agree with Billy, review this step of laser install.
              • Andyboachie
                • 185
                Thanks! I will work that out as soon as I get there. I will be back with a feedback.
                • 20 year tech
                  • May 2014
                  • 577
                  That model has 2 laser units one for yellow and magenta and one for Black and cyan, they would both have to be misaligned exactly the same to cause that or you would have major color reg issues. something is tweeking the paper as it is going thru, I had a 5550 a while back that had a small label stuck to the reg roller it changed the tension on one side just enough to twist the paper on the way thru.
                  • Venom
                    Technical/IT Support
                    • Nov 2009
                    • 765
                    After looking at 3rd sample, there is a void line that is skewed...therefore it is a paper skew.
                    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    • Andyboachie
                      • 185
                      I think that is very worthy of consideration. I would need to pay attention to the movement of the paper as it goes through.
                      I will get back with the results when I'm done.
                      Thank you!
                      • Andyboachie
                        • 185
                        Hello Friends,
                        I finally could solve the tilt issue on the IRADV 5045 yesterday. I needed to replace the fixing unit to correct the error.
                        As before, I'm grateful for your efforts in making meaningful suggestions on the issue.
