YELLOW BACKGROUND
  • Jama
    • Jul 2020
    • 49
    [CQ] YELLOW BACKGROUND
    Have the canon advance IR c3025i, am getting yellow background on all my prints and colour copies, black and white much ok. ITB brand new, drums 60% new, any leads to this yellow background ?
    Re: YELLOW BACKGROUND
    developer
    • Jama
      • Jul 2020
      • 49
      developer
      60% new developer
        • 16391
        60% new developer
        Just because it's 60% doesn't mean it's working correctly. Are you sure the drum blade is cleaning properly? Have you inspected the DV unit?
        • Jama
          • Jul 2020
          • 49
          Yes, inspected everything, cleaning blade even tested, but yellow and cyan background appears
            • 16391
            Can you scan an example? That would help greatly.
              • 16391
              By the way, are you using OEM or compatible toner?
              Have you calibrated the machine?
              When did the problem start and what have you done to correct the problem?
              What's the life counter on the machine?
              • Jama
                • Jul 2020
                • 49
                ok thanks, will take some photos and scan for example..
                  please upload in PDF format
                  • Jama
                    • Jul 2020
                    • 49
                    ok
                    • techandtrader
                      • Jun 2016
                      • 330
                      My experience is that the drum will be toast. The steel frames also contributed to this problem on the C5000 series.
                      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
