counter report
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    counter report
    Hi to all!
    Maybe someone has figured out how to print a complete counter (all counters) like P-print or similar. I need it on IPC-750.Thanks.
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: counter report
    As far as I know, it is not possible to print all counters reports
    If the machine is connected to eMaintenance service, by connecting with your mobile phone and launching the eMaintenance for Mobile APP, you can view all the counters.
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • zoraldinho
      • Mar 2008
      • 5009
      Re: counter report
      Thanks G but machine is not in the network.I also believe there is no possibility of a printout.
        • 23007
        Re: counter report
        So if the plotter won't print, and it's not on a network to view the web interface, you'll have to stand in front of the machine, and browse the menu. If it comes up in error, you can still boot in service mode, then browse the menu.
        You could connect to your laptop, then browse the web interface. I've done this before when the display was unreadable. =^..^=
        • zoraldinho
          • Mar 2008
          • 5009
          Re: counter report
          Thanks D.
          It's proffesional laser printer with rip.Not a ploter.
          The customer does not have a network with internet access so I cannot look through e-maintenance for monthly bill.
          The classic counter does not have a banner1300mm counter.
          • giogi
            Engineer senior
            • Jan 2016
            • 181
            Re: counter report
            To enable the banner set the following item in the assistance modes: Lev2 COPIER>OPTION>USER>MF-LG-ST = 1
            The format sizes that can be set by by-pass go from 98-457 to 98-1200
            Enable in service modes COPIER>OPTION>USER the counters
            471 - long format
            472 - full colour banner
            473 - B/W banner
            474 - mono colour banner
              • 23007
              Re: counter report
              Sorry, I mis-read IPC as IPF. =^..^=
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: counter report
                Originally posted by zoraldinho
                Hi to all!
                I think you can show what ones you want don't you it's in service mode
                Regards Mark
