Canon Ir 3245
  • Nestopee
    • Feb 2018
    • 28
    Canon Ir 3245
    Good day, I'm experiencing this copy on the above mention copier. Its coming from the developer unit does anyone know how it could be solved.
  • copier tech
    • 8132
    Re: Canon Ir 3245
    When the dev unit spacers wear down you get this issue.
    I would simply replace the complete dev unit or if you are on a budget replace the dev roller, seals, bearing & spacers.
    • Nestopee
      • Feb 2018
      • 28
      Re: Canon Ir 3245
      Thank you so much, I have change many units because of this problem. I'll get the spares and refurbished them. Thanks.
