How to remove laser unit of IR adv c7260
  • tomson25
    • 104
    [Misc] How to remove laser unit of IR adv c7260
    Hi friends,
    If any body have documentation for laser unit removal of IR adv c7260.plese share it.
    Re: How to remove laser unit of IR adv c7260
    Originally posted by tomson25
    Hi friends,
    it's in the service manual . you will need that for adjustments after the install.
    • copier tech
      • 8174
      Hi friends,
      If you don't have the service manful for this model you should not be working on it.
      Drop us an email if you need it.
      Firmware Update - Printer & Copier Firmware
      • tomson25
        • 104
        This is my email - tomson25@gmail.com
          No he said DROP them an email..meaning CONTACT HIM!
          • Lewis-H
            • Oct 2020
            • 15
            Press (Settings/Registration) → [Adjustment/Maintenance] → [Maintenance] → [Clean Feeder].
            Place 10 sheets of blank paper into the feeder → press [Start].
            Make sure that you fan the sheets of paper well.
            Use normal LTR paper.
            When cleaning is complete, try scanning again.
            NOTE
            To cancel feeder cleaning while it is in progress, press [Cancel].
            Wire Cleaning
            If streaks appear on printed output or random parts of the printed image are missing, clean the corona assembly wires inside the main unit.
            NOTE
            It takes approximately 35 seconds to clean the wires.
            Wire cleaning cannot be performed during printing.
            • khattab.al.masry
              • 212
              Here what you want and in public my friend.
              • khattab.al.masry
                • 212
                Mr phil
                Hi mr reputation
                What about the evaluation after my contribution.
                Sent from my CPH2015 using Tapatalk
                  NOTE
                  Wire Cleaning
                  NOTE
                  irrelevant
                  he's asking for REMOVAL docs... you seem to be posting BS just to up your numbers... we are on to you.
                    Originally posted by khattab.al.masry
                    Mr phil
                    Hi mr reputation
                    what contribution? you mean the PDF?
                    comments like this needs no evaluation
                    • khattab.al.masry
                      • 212
                      NEVER MIND THANKS SIR.
                        You need to remove the image reader that weighs bout 40kg - 88lbs probably better to separate the feeder from the scanner.
