Starting up IP message
  • jacobroach89
    • Jul 2018
    • 6
    Re: Starting up IP message
    ARE YOU a tech or enduser?
    what do you mean " check network "? this sounds like a setting isn't quite right
    if you can ping why replace all those expensive boards?
    please post settings for the network.
    you are 'shot gunning' the repair without knowing the CAUSE of the problem. rookie move.
    do you have the manual?
    what is the SPECIFIC MESSAGE?
    Phil B. ' The Dentist '
    • jacobroach89
      • Jul 2018
      • 6
        well the FACT that your lapper prints to indicates a BAD CABLE ...
        you could print to it but swapped boards? WHY
        I always start with the simple shit that a dumbass user can screw up .. THE CABLE.. or NETWORK
        is it set for DHCP or STATIC (preferred) with it set to DHCP IF the machine is turned off ( or sometimes long sleep mode ) DHCP can reassign that IP addy.
        reason I asked about the 'tech' thing your profile doesn't state ANY tech experience ... really it says NOTHING about you. WHY NOT?
        this info helps us determine whether to treat you like an end user or someone with a working knowledge of machines.
        frankly IMHO you blew it by not looking at cable/network before you started swapping boards around.
        I would have razed any of my techs for doing that... KISS principle is ALWAYS a good place to start
        • MunsterTech
          • Sep 2014
          • 381
          hi,
          did you ping it with the -t command and then take out the cable to see if it stops pinging? Maybe the IP address is pinging but to another device on the network?
          • jacobroach89
            • Jul 2018
            • 6
            • jacobroach89
              • Jul 2018
              • 6
              Originally posted by MunsterTech
              hi,
                • 16416
                Yeah, you could have an IP conflict with 2 devices on the same IP address. I'd scan the network and look at all the IP addresses being used.
                • tsbservice
                  Field tech
                  • 8020
                  Process of elimination is when you connect your laptop directly to machine with their own cable if it works - machine side is good. It's that simple no matter how many main boards you have handy or machine next room is working etc. Going alternative ways is basically chasing your tail imho.
                    exactly the point I was trying to make... thanks brother!
                      • 16416
                      +1000
                      It reminds me of an old saying I heard: "If you hear hoofbeats look for horses, not zebras."
                      • Blizzoo
                        • Aug 2013
                        • 608
                        Does your Canon have the option to change/lower the network speed?
                        • jacobroach89
                          • Jul 2018
                          • 6
                          ended up being a corrupted Hard Drive
                          thanks.
                          • jacobroach89
                            • Jul 2018
                            • 6
                              • 23009
                              hi,
                              That's what I was reading for: Duplicate IP!
                              Take the MFP off the network, then ping the address. If something answers it's not your MFP. =^..^=
