Canon IR Advance 6555i Light copies and prints What should I do?
  • bryant28282000
    • Jul 2012
    • 145
    Hello everyone, I got a Canon IRC 6555i with very little copies. Its been sitting for about a year in a warehouse with about 90k. The copies appear to be kind of light so here are the things that I did
    1. Clean the Primary Charge unit
    2. Clean the other charge unit, they both are clean as a whistle
    3. Installed a brand new developer
    4. Toner is OEM
    5. Pulled out that small laser slit glass and clean it. It was clean and not dirty
    I am attaching a sample of what I am getting. I hope its just an adjustment of something easy.
    Should I pull out the laser unit?Xerox Scan_10172020210037.PDF
    This machine is so clean and no toner dust.
  • copier tech
    • 8142
    Re: Canon IR Advance 6555i Light copies and prints What should I do?
    4. Toner is OEM
    Should I pull out the laser unit?[ATTACH]47019[/ATTACH]
    If the machine has ben sitting for a year you may find the image will darken with use, try running around 100 duplex prints so if the quality improves.
    The drum gets a film on it over time if not used so if this doesn't work remove & clean/polish the drum with alcohol.
