Canon C5250 printing issue
  • bush_tech
    • Jul 2018
    • 51
    Hey all
    Got a Canon C5250 that is outputting every job from every PC office wide to A3, all drawers are displaying the correct size
    Driver set to A4 but all print jobs come through asking for A3.
    Tried restarting everything and reinstalling the driver, anyone seen this? (using UFR driver)
    Cheers
  • bush_tech
    • Jul 2018
    • 51
    Re: Canon C5250 printing issue
    Originally posted by terramobil
    Is the driver installed on a server or on ervey client PC? Which application you are printing from? What happend if you are printing from your laptop?
    Locally installed drivers, all applications including windows test page. Remoted in to install fresh driver on one of the PCs and do some testing
    Haven't been able to print from my laptop as the client is about 6.5 hours drive from me, trying to avoid heading out there hopefully
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by bush_tech
      Hey all
      Cheers
      Could be how the document was setup does driver test page work OK also turn on auto continue or error skip on copier use UFR 11
      Regards Mark
      • copier tech
        • 8174
        Sounds like you have auto paper/tray select set up wrong, A4 not enabled, see link below.
        Enabling Paper Drawer Auto Selection
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Have the customer change the cassettes around so A3 is where A4 was and vise versa. That way you can see if the driver is set to print to a specific cassette.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • MunsterTech
            • Sep 2014
            • 381
            hi,
            if the customer is that far away, could you not use RSOK and team viewer to log on to the machine remotely and see if you can adjust settings.?
            • bush_tech
              • Jul 2018
              • 51
              I will look into this
              • Lewis-H
                • Oct 2020
                • 15
                If you intend to print using TCP/IP, in order to install the printer driver correctly, communication via the IP address of the computer on which you intend to install the driver must be permitted in [Firewall Settings] on the machine. Check whether communication via the IP address of the computer is permitted in [Firewall Settings] on the machine. (See steps 14 to 17 in "TCP/IPv4 Settings," or steps 12 to 14 in "TCP/IPv6 Settings.")
                • nicknt82
                  • Nov 2011
                  • 155
                  Hey all
                  Cheers
                  Check this setting on Photocopy: Setting- Function setting - Printer setting-UFRII setting- Default paper size
                  Accessing the Settings Menu
