Canon IRC 5560i. Mac Drivers only print double side
  • bryant28282000
    • Jul 2012
    • 147
    How do you get a Mac to print 1sided copies? It keeps printing duplex and I have tried Postscript as well as generic and it dont work. in the print screen 2sided is graded out
  • GIUBOSS
    • 1437
    Re: Canon IRC 5560i. Mac Drivers only print double side
    you have also installed the PPD
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      IN TERMINAL: sudo cupsct1 WebInterface=yes
      IN SAFARI: http://localhost:631
      Head to printers section, Find your printer, Administration, select Set Default Options, Find and change the two sided option, Set Default Options
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
