Canon IR 3300 Photocopier Printing Black
  • princepriyu
    • Aug 2025
    [Misc] Canon IR 3300 Photocopier Printing Black
    Hello Friends
    my Canon IR 3300 Photocopier is Printing Black and Just Black
    what may be the problem, please can anybody help me to solve this
    Note. it prints Just Black, even i print it from computer or mailbox or even photocopy (Scan & Print)
    i have even tried to print the configuration page from it even it prints black
    (Configuration Page :- Additional Functions >> Report Setting >> Printer >> PCL or PS >> Configuration Page >> Print Configuration Page >> Yes)
    even this is printed BLACK
    Please any solution . . . . MOST WELCOMED
    Thank You So Much
    Regards
    Canon IR 3300 BLACK PRINT 03.jpg Canon IR 3300 BLACK PRINT 02.jpg Canon IR 3300 BLACK PRINT 01.jpg
  • Brian8506
    • 1665
    Re: Canon IR 3300 Photocopier Printing Black
    Did you replace anything yet like the drum?
    • princepriyu
      Thanks for the reply
      but not exactly, i just removed it and cleaned the drum (OPC Drum) and the PCR (charging Roller), and fixed as it was previously, i have done this several times before but never faced such a thing.
      what actually do you think went wrong, what i need to check now. . . .
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Landfill machine.Bad drum,developer,fixing unit..
        • Brian8506
          • 1665
          I think if you want to fix the machine you should try replacing the drum unit.
          • copier tech
            • 8174
            There were a great model back in the day I still look after one myself.
            From your samples I can not see a lead edge so check the drum earth but if you have a spare drum unit try that.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              There's your problem try replacing as a unit
              Regards Mark
              • kuby
                • Oct 2007
                • 1409
                Replace the DRUM unit.
