Firmware
  • riyadh hossainbd
    • Dec 2015
    • 239
    Firmware
    Can someone give ir5000 firmware?
    Thanks in advance
    riyadhhossain1988@gmail.com
  • copier tech
    • 8195
    Re: Firmware
    Thanks in advance
    • charm5496
      • 2387
      Re: Firmware
      Thanks in advance
      Unless you have the old canon USB to parallel cable, you are going to have a hard time installing this firmware.
      • copier tech
        • 8195
        Re: Firmware
        He can instal this via the LAN port.
        • charm5496
          • 2387
          Re: Firmware
          That was an option on the 5000 series, and even then it was a 50/50 shot of it working properly. Then you had to know if the boot rom was a N, C or an I version before loading as well. The older Canon devices are not as straightforward as today's models when loading firmware.
          • copier tech
            • 8195
            Re: Firmware
            Even the C boot rom models have a LAN card as standard.
            • charm5496
              • 2387
              Re: Firmware
              No they did not, and you are horribly wrong. The base model machine had to have the PDL KIT-A2 installed and it came with N boot rom and the NIC port.
              It wasn't until the 'I' version was released that the NIC card was standard, and then when the 5020/6020 was released did Canon start including the NIC card.
              • copier tech
                • 8195
                Re: Firmware
                I only saw these with a LAN card maybe this was the only one marketed in The UK.
