Canon MF6550 - display and toner problems
  • kuby
    • Oct 2007
    • 1409
    Machine's display is off...when starting up you can see all of the pixels lighting up, but when the image comes up it is all pushed to the left about a inch or more...
    Machine keeps saying to Prepare Toner Cartridge, or put cartridge in. It is New Canon cartridges being used....no matter which one I put in it displays this. And then all of a sudden it will take one of the cartridges and start working for a while.
    What to look for??? Have already pulled the display and it looks OK, inspected the contacts around the toner cartridge and everything looks OK..Help
    Got display problem fixed - working on toner problem.
  • freedomtt
    • 50
    This entire series is notoriuos for having the false toner messages, the only fix that I have found to consistently work is to use Canon FX-11 cartridges and just grind off the one post that gets in the way. The FX-11's are also a lot cheaper (wholesale anyway) than using Canon 106's or HP cartridges
    • haydar64
      CRG 706 MUST USE FOR THIS MACHINE.
      if u installed a new toner, pls remove and install again. or off and on your machine.
      • cucuklotz
        • Mar 2007
        • 611
        CRG 706
        HI,
        What is CRG 706?
        THANKS< ANDY
        • haydar64
          Originally posted by cucuklotz
          HI,
          What is CRG 706?
          THANKS< ANDY
          CRG 706 is toner cartridge for Canon MF65xx series machines. (For Turkish)
          Canon PC Cartridge 106 0264B001 (For Canada & USA )
          Canon imageCLASS MF6550
          follow this link for see this toner cartridge.
          P.S. : dont use any other toner cartridges. may be as same but, ur machine can show many errors at time...
          HAYDAR64
          • freedomtt
            • 50
            The compatibles have come along pretty well for this model. We had a load of problems to begin with but it seems to have been taken care of buying using Canon cartridges or good quality refills (I know, practically an oximoron)
            • haydar64
              well, and u can refill this cartridge with C-EXV7 TONER ( IR-12xx series toner)
              C-EXV7 toner is same as CRG706 (Cartridge106)
              this way is cheaper than all others.
