Touch Screen issues with IR4525iii
  • Copybox
    • Sep 2020
    • 59
    [Misc] Touch Screen issues with IR4525iii
    I have recalibrated the touch screen on this machine (the touch icons were all over the place and glitching when pressing) but the issue keeps on reocurring. I have done a firmware update - no fix. Are there any other updates available as i think this is a software issue??
  • Brian8506
    • 1664
    Re: Touch Screen issues with IR4525iii
    I believe the CPU board in panel is a problem on that series
    • copier tech
      • 8164
      If the machine can print & the hard keys work sounds like you have a failing touch pad so either clean or replace it.
      We have a few issues like this usually down to customers "sanitising" the screen.
      โ€‹
      • Copybox
        • Sep 2020
        • 59
        Thanks Brian,
        Can the CPU board be changed? If it can do you know the part no??
        Cheers
          Thanks Brian,
          Cheers
          frankly you should get a manual for the machine if you plan on working on it anymore.
          per forum rules all manual requests are to be made in this forum -----> https://www.copytechnet.com/forums/s...nual-requests/
          • Copybox
            • Sep 2020
            • 59
            That figures, as the glitch was reported around August time. Another tech stated that this version of machine has a temperamental CPU board?? (FM1-X896-000) so a bit stuck as to where to start. The touch pad check is obviously the most cost effective option to start with
            • copier tech
              • 8164
              Before ordering any parts I would strip the panel down & clean the touch pad contacts often that is all that is required.
              โ€‹
