Cannon ipf770 error
  • Manoj ambatt
    • Oct 2019
    • 25
    [Error Code] Cannon ipf770 error
    Gd evening friends
    I have a problem with cannon ipf770 printer
    It was initially given bad print out
    I clean the head and install again, now it is giving an error
    038000500 - 2f40, anybody have idia about it?
    Pls help
    Re: Cannon ipf770 error
    Originally posted by Manoj ambatt
    Gd evening friends
    Pls help
    how did you clean the printhead? with what?
    are you using third party ink?
    • copier tech
      • 8142
      Gd evening friends
      Pls help
      Did you physically remove & clean the printhead or run the head refresh etc?
      • Code: 2F40
      • Display:Hardware error. 03800500-2F40 Turn off printer,wait, then turn on again.
      • Description:When the result of non-ejection detection is as follows. When non-ejection has been detected for all nozzles of all colors -The error code assuming a problem in the supply system/ purge system/ main controller PCB (electric).
      • Manoj ambatt
        • Oct 2019
        • 25
        I remove the printhead from the printer and clean with ipa
        Using original I k
        • Manoj ambatt
          • Oct 2019
          • 25
          Using original I k
          Is this issue can be solved or need to replace print head?
          • copier tech
            • 8142
            Most likely you will need to replace the printhead.
            They are designed with a lifespan & they dont like being cleaned.
            Try cleaning the printhead contacts & restarting the printer a few times it may recover.
