Canon C5240a Transfer Belt Needs to be Adjusted
  • rpfo1234
    • Aug 2025
    [Error Code] Canon C5240a Transfer Belt Needs to be Adjusted
    Hello everyone, I'm hoping someone can help guide me on adjusting the ITB belt on my Canon IR C5240a
    I am receiving the error E000075-0103 and cannot operate the printer
    I pulled up the ITB POS values in service mode and it reads the following values
    ITB-POS 249
    ITB-POS2 -147
    I have tried repositioning the machine and that hasn't helped.
    I will show photos of the ITB belt, please let me know your thoughts.
    I'm having a hard time attaching images, the links for them are below
    itb-belt-1 — ImgBB
    itb-belt-2 — ImgBB
    itb-belt-3 — ImgBB
    itb-belt-4 — ImgBB
    Thanks,
  • copier tech
    • 8192
    Re: Canon C5240a Transfer Belt Needs to be Adjusted
    ITB-POS 249
    ITB-POS2 -147
    itb-belt-1 — ImgBB
    itb-belt-2 — ImgBB
    itb-belt-3 — ImgBB
    itb-belt-4 — ImgBB
    Thanks,
    There are loads of bulletins on this issue.
    What I found works best is to remove the best & clean the large rubber drive roller so its 'grippy'
    And update the SSW to the latest version.
    Also see my post here:
    Canon iR ADV C5255 - Error E075-103
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      I set belt to the right position by hand then i move the ITB motor up or down (two screws). Depending on which direction the tape escapes.
      A few time run itb init then check values in service mode.Its work for me beter then all bulletins together.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        ITB-POS 249
        ITB-POS2 -147
        Thanks,
        Belt has moved out of place best to know what you are doing call Canon credited service engineer
        Regards Mark
