CANON Image runner 8105 advance hdd hard drive
  • pambos100
    • 6
    Hi
    i need your help
    I buy 2 x image runner 8105 advance without hard drives
    I have bought the firmware and successfully put via the service tool on a USB.
    I install 12 hdds with + 1 given to me by canon itself (Toshiba MK1676GSX)
    Iboot using sequence and get option 4 to format.
    But not successful it says.
    Any chance to know how i can proceed as i am Stuck !
    pam
  • pambos100
    • 6
    Re: CANON Image runner 8105 advance hdd hard drive
    • Arcadian
      • Feb 2010
      • 218
      Originally posted by pambos100
      Hi
      i need your help
      pam
      what type of hdd are you installing??? they have to be a certain size, and speed from what i recall.
      • pambos100
        • 6
        Toshiba 80gb MK1676GSX
        • Arcadian
          • Feb 2010
          • 218
          wow i thought they used the 160gb one of toshiba. or bigger. but not larger than 320gb. so try a larger size but no bigger than 320gb. and keep it under 7200rpm, use only the 5400rpm ones.
          • pambos100
            • 6
            Maybe this hdd is wrong
            • Arcadian
              • Feb 2010
              • 218
              its possible wont hurt to try another one, once you made one, always good to make a backup and put inside the machine with a note saying its a backup drive. that way dont have to find all the files again.
              • copier tech
                • 7934
                Hi
                i need your help
                pam
                This is the part number you need, googlr this & buy an identical HDD this will work.
                Canon have written into the firmware a list of around 10-15 models of drives that it will accept, any not on this list will give the issue you are getting.
                FK2-8418-000
                • pambos100
                  • 6
                  FK2-8418-000
                  ANYONE HAVE THIS LIST?
                  Please
                  • copier tech
                    • 7934
                    Please
                    OK so it seems they will accept 80GB - 250 GB but no mention of make & model.
                    Canon U.S.A., Inc. | imageRUNNER ADVANCE 8105
