Need help with some projects with CLC 3220 with fiery X3e-01
  • Michael
    • 158
    #16
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
    • 20 year tech
      • May 2014
      • 577
      #17
      Re: Need help with some projects with CLC 3220 with fiery X3e-01
      Here is the service guide for the imagepass C1. you will need a computer with a parallel port and the system software cd ( I don't have one) its been over 15 years or so since I have touched one of those but if memory serves me correctly those were very finicky boxes and the initial boot takes forever. good luck.
      C1_SG.pdf
      • Michael
        • 158
        #18
        [ATTACH]47613[/ATTACH]
        thanks a lot ,i have an windows xp machine near the copymachine with lpt port.
        but now i need the system software for the fiery. maybe another user here have this.
        thanks michael
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          You must have a good hard drive that is designed for that model to clone for the copier if you try to clone the firey hard drive to use in the copier you will not be able to use in fiery again as you would of wiped the system software of it.
          You can't download the fiery system software I don't think you have to buy cd disk with comes with fiery when new.
          Also these machines are very very old now but was a good machine.
          Regards Mark
          • Michael
            • 158
            #20
