Imagepass c1 HDD died
  • Michael
    • 158
    [Dead] Imagepass c1 HDD died
    Hello,
    i need some help to bring up the fiery again. The old HDD is completly dead. I had make an image before it died but this not work.. So i need to install a new harddrive and the system software. For this i need help.
    1. How can i find out which HDDs working with C1
    2. I have the C1 2.0 Software but no info how to install.
    3. on died HDD was 2.1 is this available anywhere?
    4. is it possible to download the system software from a working c1 fiery to install it on another c1 fiery?
    hope to get help here.
    this forum is really great..
    Michael
    SN c1: jxnxxxxx 128 mb ram
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
  • Michael
    • 158
    Re: Imagepass c1 HDD died
    Hello....
    i have done the job :-)
    Here some information which maybe usefull for some users.
    I installed the System as described in instruction.
    1. i tried a 40 gb which i lay around and install the system -> it works . Panel says now more memory then before
    2. i tried a brand new 80 gb which i had install system -> it works. Panel says much more memory :-)
    Difference between C1 v1.x and C1 v2.x Motherboard: v1.x not shutdown with copier and not switch on with copier, only v2.x motherboard do this. They have additional pcb inside.
    Maybe someone can give me the C1 2.1.2 Software.
