Upper fuser roller problem in canon IR advance 8205.
  • Omkarmore
    • 17
    [Electrical] Upper fuser roller problem in canon IR advance 8205.
    Can I use non-OEM upper roller in canon IR 8205.
  • GIUBOSS
    • 1436
    Re: Upper fuser roller problem in canon IR advance 8205.
    hello are you a technician I guess (?), not all compatible are the same, usually I do not recommend the compatible but sometimes for economic or time reasons being a black and white and also old try it.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Best to use oem last much longer buy cheap you will pay twice
      Regards Mark
      • Omkarmore
        • 17
        How I can differentiate oem upper roller vs non-oem upper roller.
        I have my old upper roller and FL3-3600-95J written on it . Can you tell me this is oem or not .
        Thanks in advance.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Thanks in advance.
          Thats the wrong number it doesn't even come up on Google here's correct number
          Regards Mark
          • Gab
            • Aug 2015
            • 671
            Yes you can but not are the same and none like genuin.
            • AL parts
              • Jun 2019
              • 61
              The compatible upper fuser roller of this model is not easy to use, and error codes are prone to appear.
              www.gzanling.com
              • tinnyjay
                • Oct 2009
                • 663
                I would not suggest. Its the 8105 & 8205 can't use non-oem upper fuser roller and the reason is the temperature that goes higher and higher till you'll face E004 after 3-5 mins of printing.
                The temperature in the middle of the roller goes much higher than the sides.
                "Who loves the roses,must also bear thumbs"
