Canon IRC ADV C9065 CONTROL PANEL BLANK DISPLAY
  • browny
    • 81
    [Misc] Canon IRC ADV C9065 CONTROL PANEL BLANK DISPLAY
    Hello all
    I have canon IRC ADV 9065 , control panel is BLANK DISPLAY ... but it has green light at the lower corner .
    PLEASE HELP , I can find it in SVC manual , Thank you
  • copier tech
    • 8174
    Re: Canon IRC ADV C9065 CONTROL PANEL BLANK DISPLAY
    Originally posted by browny
    Hello all
    What have you tried so far?
    When you turn on the machine does it warm up? does it print OK?
    • browny
      • 81
      Thank you for reply
      Machine is normal operation ...warm up , print ... But only blank display on the control screen. ( it has blue light , can not turn on the screen )
      • copier tech
        • 8174
        Thank you for reply
        Look closely at the screen can you see its working but very dark?
        • browny
          • 81
          No thing can see on the screen : I unplug connectors cable , clean them .. connect back , turn the volume ... no way to get to see anything ... May be dead pwb
          • copier tech
            • 8174
            If it is printing ok sounds like the screen LCD has failed
