Canon IR 2870 Error Code E602-0001 HDD Error
  • Simza
    Simza
    • May 2020
    • 27
    [Error Code] Canon IR 2870 Error Code E602-0001 HDD Error
    Greetings,
    I have an issue with multiple IR 2870. It gives the code E602-0001, because the HDD was not inside the machine. After I bought 20 GB PATA HDD to install it in the machine, I learned that you need to format it first. I lack the tools and an instruction to format the HDD. I do have the firmware for the IR 2870 but no SST.
    My questions:
    -Can anybody provide me the necessary software for the HDD installation?
    -Is it also possible to hand out an instruction, on how to do it?
    I have never worked with the IR series before and am having troubles with it atm. I am very comfortable working with the newer IRA series but the older machines put me to a test!!
    I would appreciate your help very much!
    Please help a fellow technician out!
    Stay safe!
  • ahmad
    • Jun 2010
    • 28
    Re: Canon IR 2870 Error Code E602-0001 HDD Error
    Originally posted by Simza
    Greetings,
    My questions:
    Stay safe!
    dear sir
    i can send you the hdd with the system in it ready to use it will cost you 50 dollars exclude the shippment cost
    regards
    ahmad anany
    • Simza
      Simza
      • May 2020
      • 27
      Dear Sir,
      thank you for your offer, but i need a proper solution.
      I am dealing with copiers, so i have receve a rollback from 60 copiers (2870/3025/3045).
      I am trying to arrange a device to clone the HDDs. But its difficult to find a clone unit IDE 2,5" to IDE2.5".
      If anybody can provide SST v4.04Eq - New. I think i can solve my matter very well.
      Thanks a lot
      Stay safe
      • Michael
        • 158
        My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
        You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
        • copier tech
          • 8195
          Greetings,
          My questions:
          Stay safe!
          You can not fit simply any HDD it has to be on the Canon supported list.
          To guarantee to get the correct HDD order an identical one that failed.
          Once you have done this upload the firmware using the SST.
          Drop us an email should you require this.
          Firmware Update - Printer & Copier Firmware
          • nicknt82
            • Nov 2011
            • 155
            Greetings,
            My questions:
            Stay safe!
            I know software to do that. Inbox me for price
