Canon ir3025
  • sameh
    • Oct 2014
    • 19
    [Jamming] Canon ir3025
    In A3 paper when the paper output the last quarter of paper is curle
  • sameh
    • Oct 2014
    • 19
    Re: Canon ir3025
    When the paper comes out, the last part of it is shrinking
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Re: Canon ir3025
      try fresh paper.....you a tech?
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • 22808
        Re: Canon ir3025
        can't tell the only thing on his profile is name and birthday
        as with this thread sounds like he doesn't want to give out info
        • sameh
          • Oct 2014
          • 19
          Re: Canon ir3025
          No not problem fresh paper
          I used fresh paper but no solve
          • copier tech
            • 7931
            Re: Canon ir3025
            If you have tried a new packet of paper & the prints are still coming out curled.
            Replace the fuser sleeve AND the pressure roller.
