Cannon 2200 Imagerunner HDD failure
  • k112098
    I have a Canon 2200 Image Runner copier. I know its a bit old, but its what I have. Today I received an error code E602-0001. From what I have found this means a bad hard drive. I would like to find out if there is a way to fix my issue. I can buy a new drive, but is there system software that needs to be installed. If so, is there some place I can obtain a copy to fix my broken system?
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Search the forums...every answer you need relating to iR2200's and HDD issues is here..believe me
    • kuby
      • Oct 2007
      • 1405
      You can try running disk check on the drive and see what happens. With the machine OFF, press and hold down the 1 and 9 keys down, turn the machine ON and continue holding the keys down until the screen changes to a blinking cursor. Go to breakfast, lunch, or go home and let it run. It will try and repair bad sectors if it can. If it can't then you need a new hard drive.
      • haydar64
        u must try upgrade or rewrite your hdd/system
        RapidShare: Easy Filehosting
        download this file and upgrade or rewrite your copier's hdd.
        this file is not include SST. u can download any 3.xx SST and install this system.
        HAYDAR64
