Canon C5045 finisher removal
  • shaunt
    • Jan 2021
    • 2
    [Misc] Canon C5045 finisher removal
    Hi guys! I'm so happy that I have stumbled across this forum as it seems like an absolute wealth of knowledge. I am wondering if someone would be able to help me.
    I have inherited the job of moving a Canon imageRUNNER ADVANCE C5045 that has the C1 Staple Finisher and B1 Hole Punch unit attached. Does anyone know how to remove both of these? I won't be able to move it from where it is with them attached due to a lack of space and tight corners. I have checked the service manual for an installation guide of some sort, but haven't managed to find what I am looking for. I have taken some panels off but can't seem to see where anything disconnects from the main unit itself. Before I go and take a screwdriver any further and pull what is left of my hair out, I was hoping that someone had a more direct/official/tried and tested way of doing this.
    Many thanks in advance,
    Shaun
  • copier tech
    • 8202
    Re: Canon C5045 finisher removal
    Shaun
    Very simple to remove the finisher from the coper, you can keep the holepunch attached to the finisher & move it as one piece.
    Here's the installation guide.
    Staple Finisher-C1 - Booklet Finisher-C1.pdf
    • shaunt
      • Jan 2021
      • 2
      [ATTACH]47883[/ATTACH]
      Thank you so much! I feel like an absolute idiot for not noticing this at all. That took all of 30 seconds. You're an absolute lifesaver!
      • copier tech
        • 8202
        No worries, that hidden latch is not immediately obvious.
        • zonksoft
          • Dec 2023
          • 1
          • copier tech
            • 8202
            No problem.
            We can also supply the latest firmware should you wish to update your device.
