Image advance 6075
  • saintphotostat@gmail.com
    • May 2016
    • 10
    [Error Code] Image advance 6075
    Ir advance 6075 error code E 00067-00001,replaced almost probable pcb's and devoloping unit no result any idea?
    Re: Image advance 6075
    why start replacing boards before you have diagnosed the REAL problem? A real rookie move IMHO.
    what part of the machine does the error code point to?
      Has the torsion spring come off the buffer assy?
      • copier tech
        • 8205
        • Code: E067-0001
        • Description: Developing high voltage output leak error
          The leak detection signal was detected 5 times in a row for every 20 msec.
        • Remedy: 1. Check the connection between the Main Driver PCB (PCB2) and the High Voltage Unit. Main Driver side: J112, High Voltage Unit side: J3098 2. Check the connection between the Relay PCB (PCB5) and the High Voltage Unit. Relay side: J519, High Voltage Unit side: J3099 3. Replace the Developing Assembly. 4. Check the connection point of the Developing Assembly. If it is soiled, clean it. 5. Check the connection inside of the High Voltage Unit. Check the connection of the High Voltage Unit Relay (J3097) and the Developing High Voltage PCB (J3511). High Voltage Unit Relay (J3099) and Pre-transfer Charging PCB (J3545, J3500, J3510) 6. Replace the Main Driver PCB (PCB2).
        โ€‹
        • Brian8506
          • 1667
          Did you check to see if the pre-transfer wire was broken?
