Error 001-000 Canon 5045
  • JeeDayHS
    • Jan 2021
    • 18
    [Error Code] Error 001-000 Canon 5045
    Hello,
    I have problem with canon 5045, error code E001-000.
    The steps i took:
    Change fuser
    Change DC controler
    Change Main 1 controler
    Change High-voltage PCB
    Change Shooter
    Change complete unit IBT
    Change complete drums and developers unit
    And still didnt fix problem
  • copier tech
    • 7931
    Re: Error 001-000 Canon 5045
    Originally posted by JeeDayHS
    Hello,
    The steps i took:
    Change fuser
    Change DC controler
    Change Shooter
    Did you reset the error in service mode?
    • JeeDayHS
      • Jan 2021
      • 18
      Of course
      • copier tech
        • 7931
        Of course
        Why did you replace these items "Change Shooter, Change complete unit IBT, Change complete drums and developers unit"
        And what is the "shooter"?
        Try updating the firmware.
        E0001-001 .pdf
        • JeeDayHS
          • Jan 2021
          • 18
          [ATTACH]48071[/ATTACH]
          That is step in service manual
          Replace the Fixing Shutter Unit
          Ibt and drums unit i replaced because i was desperate.
          I tried that but still didnt fix the problem
          i tried update but still didnt fix the problem
          • mc007
            reliable tech
            • Jan 2019
            • 28
            Hello,
            The steps i took:
            Change fuser
            Change DC controler
            Change Shooter
            check fixing drive gears
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Hello,
              The steps i took:
              Change fuser
              Change DC controler
              Change Shooter
              The problem will be the film assy or shutter don't know why you would of replaced the other parts the fuser unit was it new you said shooter did you mean shutter it would of been on the fuser that you already replaced try replacing new oem fuser film assy and then clear in service if that doesn't work replace the shutter it's usually the film assy are you trained. Also as copier tech adviced update system software
              Regards Mark
                • 22808
                the 'shotgun' repair approach is silly.. time consuming and wastes good money
                • JeeDayHS
                  • Jan 2021
                  • 18
                  Allready check + i check motor
                  • WLIT
                    • Jan 2020
                    • 40
                    As you may know, the code is for an excessive temperature reading of main thermistors. If it happens in front of you do you feel any heat in the fuser assembly or could it be a false code due to bad fixing film assembly? You could also check the fuser temp under Display in Service Mode. Reset the error and turn off mfp. Then open the side door, go into service mode under Display and watch the fixing temperature as you close the door. I see you said you replaced it but still could be another bad one. And don't forget that you need to reset that error every single time it is thrown. Otherwise it should be cooling fan or shutter issue.
                    Also, I would check the Error log to see if there isn't some other underlying error there prior to seeing the E001.
                    • techandtrader
                      • Jun 2016
                      • 317
                      Wow E001 After a new fuser. Try a new Fixing drive or at least the updated drive gear shaft. There was a tech pub on this and I updated several to the new shaft that drives the fuser unit. The shaft and bearing fit will fail and cause slippage. C3480 will fail the same way with intermittent e001. Normally around 1 million clicks.
                      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
