Canon iR-ADV C2220
  • trawe
    • Mar 2019
    • 13
    Canon iR-ADV C2220
    Touch panel is unresponsive = still the same after replacing
    possible will be fixed if we reload firmware?
    i need firmware for this model and willing to trade ir-adv c5045, konica c452, ricoh mpc 4503 firmwares
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon iR-ADV C2220
    Touch panel is not a problem but panel pcb.
    You can update firmware with updater in service mode.Printer must be on network.
    • trawe
      • Mar 2019
      • 13
      hi zoraldinho,
      ok copy, will try this one, thanks
      • copier tech
        • 8222
        There was a bulletin on this issue, see attached.
        IRAC 22xx failure of the touch panel and keypads.pdf
        • trawe
          • Mar 2019
          • 13
          [ATTACH]48117[/ATTACH]
          Thank you for this service bulletin, i will try this one.
