Strange Symptoms with CLC 3220
  • Michael
    • 158
    [Misc] Strange Symptoms with CLC 3220
    Hello everybody, i need your help.
    my copier have strange symptoms.
    It started with the fact that double-sided copying via the ADF no longer worked. As soon as the copier started copying, it went into error and the touch panel was empty. One-sided copies still worked. Likewise, scanning and printing from the PC. Now you can neither copy from the glass nor print. Every time the copier starts, it stops and the touch panel is then empty. You can see the backlight, but it no longer reacts to touch or buttons.
    any ideas?
    thanks in advance
    Michael
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
    Re: Strange Symptoms with CLC 3220
    Reseat the memory DIMMs, the boot ROM, and the control panel connectors.
    • Michael
      • 158
        Any error codes?
        • copier tech
          • 8163
          When the HDD is failing you get weird issues like this.
          Try formatting the HDD then reloading the SSW using the SST.
          • Michael
            • 158
            Originally posted by skynet
            Any error codes?
            • Michael
              • 158
              before reformat, what must i save before from the copier or print out?
              thanks michael
              • copier tech
                • 8163
                thanks michael
                If you can access the RUI back up the address book ?
                • Michael
                  • 158
                  i have no adressbook...
                  if i format the hdd, does i lost the config from copier?
                  • copier tech
                    • 8163
                    Well only the ip address but thats simple to re enter.
                    • Michael
                      • 158
                      I mean would i lost german language in panel? mmi settings or other setting inside the copier? where can i get the german language file for downloading to the copier?
                      • copier tech
                        • 8163
                        When you reinstall the SSW you can set the German language again.
                        • Michael
                          • 158
                          but would this not need german language files in sst? if i remember right i have only english language files.
                          • copier tech
                            • 8163
                            Yes you need to have the German language installed in the SST first.
                            However surely English is good enough on a down machine!?
                            • Michael
                              • 158
                              only if people know english :-)
                              maybe anybody here have german language files for the sst ?
