Canon image runner 2206.....downloading please wait
  • AhmedChamumi
    • May 2016
    • 130
    Hi,
    I have canon image runner 2206 stuck at downloading please wait, i have attended and sorted a similar problem on other older model..the problem here is i do not have the firmware as well as SST for this newer model, i humbly request for your assistance at your soonest convenience.
    Best regards,
    Ahmed Chamumi.
  • teckat
    • 16083
    Re: Canon image runner 2206.....downloading please wait
    Originally posted by AhmedChamumi
    Hi,
    Best regards,
    Ahmed Chamumi.
    If printer is connected to network, remove connection, shut down printer, power up without network cable.
    May get lucky.
    • AhmedChamumi
      • May 2016
      • 130
      May get lucky.
      Thanks for the timely reply....the printer is not connected a network.
      Best regards,
      Ahmed Chamumi
      • ss200222
        • Jan 2012
        • 21
        Hi,
        Best regards,
        Ahmed Chamumi.
        Power of the Unit, Disconnect the hdd, and re-connect, restart the unit.
        Sent from my Nokia 3.1 Plus using Tapatalk
        • copier tech
          • 8101
          Did this model even have a HDD?
          • AhmedChamumi
            • May 2016
            • 130
            Thank you so much for the input i will get back with the results.
            • teckat
              • 16083
              iR2202/2002 Series ----No HDD
              • copier tech
                • 8101
                Nope. Only way to resolve this issue is re-flashing the SSW.
                • AhmedChamumi
                  • May 2016
                  • 130
                  i havent checked yet
                  • AhmedChamumi
                    • May 2016
                    • 130
                    Where do i get that firmware sir? if you may assist please.
                    Best regards,
                    Ahmed R. Chamumi
                    • teckat
                      • 16083
                      Best regards,
                      Ahmed R. Chamumi
                      Did u unplug all connections on pcb's , then re-connect ?
                      • copier tech
                        • 8101
                        Best regards,
                        Ahmed R. Chamumi
                        We can supply this firmware should you require it.
                        Firmware Update - Printer & Copier Firmware.
                        • AhmedChamumi
                          • May 2016
                          • 130
                          Kindly PM me with necessary arrangements
                          My email is : chamumiahmed42@gmail.com
                            you have to log on to their pay website .
                            • AhmedChamumi
                              • May 2016
                              • 130
                              No sir i havent done that yet, i will give it a shot and observe, Thanks
